Hi all,
I have a problem with thematic mapping via industry models. I have some polylines which come from Oracle industry model. For the first time I need to use map units in my stylization. I have no problem with stylization but I have a problem with display manager.
When I use map units my polylines which symbol consists from two lines - one thin and one thicker to get the appearance as there is a frame around the line. I need these lines to be thick at least 1cm or thicker. Problem is that in display manager these lines become so thick that I can't visualise how that line really look like and my legend rules become useless.
![map.png map.png](https://forums.autodesk.com/t5/image/serverpage/image-id/162612i79A51916A237FD37/image-size/original?v=mpbl-1&px=-1)
Picture is attached.
First one has map size context, other have device. Problem is that I would like to see the first line like other in device size context. I know it is normal to have different appearance for these size context, but with this if I put all rules in map size context I can't know which is which and this "legend" becames useless. Same thing happens with points also if they are larger.
Any way to overcome this?
Thanks!
Sale
