AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Strange lines around object endpoints
8 REPLIES 8
Message 1 of 9
connor.daviesXY4Z8
468 Views, 8 Replies
I'm currently doing plans on Map 3D on top of aerial imagery that we have inserted as an ECW xref.
Recently I've noticed strange lines appearing at the endpoints of objects such as lines and other xrefs/images that are placed on top of the aerial. However, the lines do not appear if the object isn't crossing paths with the aerial.
They go away after zooming in/out or panning.
How do I get rid of these so they don't appear in the first place, and what are they? I have no use for them. I get the idea that they're for aligning objects but I have no need for them.
Please see the attachments for a better description. Thanks for any help.
8 REPLIES 8
Message 2 of 9
Connor,
"They go away after zooming in/out or panning."
Sounds like a graphics problem. You could try either turning off Hardware Acceleration or un-checking High Quality Geometry.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 9
Turning off HW acceleration fixes it but I cannot stand the look of everything with it turned off, its terrible! 😞
Turning off high quality rendering doesn't fix it either.
It's strange because I don't have this issue unless I am drawing over the top of an xref aerial and the GPU I'm using is more than capable for AutoCAD (correct me if I'm wrong though..).
Its not like I'm doing 3D work either. See my new attached screenshots for more info.
Message 4 of 9
Hi, Connor,
Can you try sequentially REGENMODE - 1 and REGENAUTO - ON?
But for large files, this can lead to a slowdown.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 5 of 9
Hi Alex,
Both options were already turned on
Message 6 of 9
Have you tried the ECW hotfix >>HERE<< ?
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Message 7 of 9
Thanks but I'm using Map 3D 2018 so the patch doesn't apply to my version.
Message 8 of 9
Connor,
Have you updated/re-installed your Graphics Driver? Do you have the Latest Service Packs for Map 3D and Vanilla AutoCAD?
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 9
parkr4st
in reply to: Pointdump
have you tried FDO connection of the image or iinsert raster command instead of XREF?
dave
Technology Administrators
AutoCAD Beta
