I want to edit some values in the data table of a shape file (*.shp) with AutoCAD Map 3d 2013. Every time I alter a value in data table it takes about 30 seconds until AutoCAD Map saves (?) the value. I have to wait 30 second until I can continue working. Why is this so slow?
The shape file has 7000 lines and is stored on a local drive.
Regards
Jens
Hello
Which MAP : 2013 / 2012 / 2011/ etc ?
32 or 64 bits ??
Have you tried to export your SHP file to the SDF v3 format or SQLite format ?
If possible, could you test the Edit Table FDO with the same file (coming from SDF v3 or SQLite) ?
Bye, Pat
Patrice BRAUD
Hi Jens,
delete the SHP's index file (file extension: shx). FDO provider will built a new one next time it opens the file.
Might be a corrupted index.
Rob
Thanks for the suggestions.
I use AutoCAD Map 3D 2013 on XP 32 bit.
I guess the problem depends on the size of the dwg witch I use. It not depends on the FDO data source.
I tested the following:
Test 1
1. open large dwg (14 MB with xrefs, linked blocks, ...) from an network drive.
2. FDO connection to:
- shp with old index
- shp with new index
- sdf
- sqlite
All FDO files on a local drive. In all cases it will take about 50 seconds:
a) I enter a new value in the data table
b) I press return
c) AutoCAD checks out the feature I want to edit. This takes about 50 seconds.
When I select one feature and use MAPCHECKOUT it will takes about 50 seconds too.
Test 2
Open a smaller dwg. I make FDO connection. Now it takes about 10 seconds.
Test 3
Empty dwg. FDO connection. Now it takes < 1 Second.
Test 4
While large dwg and fdo connection from test 1 is open:
I create an empty dwg and make a FDO connection. Like test 3 it takes < 1 Second.
So memory size and CPU seems to be sufficient.
Test 5
Now I attach the large dwg from test 1.
It takes < 1 Second.
My current conclusion:
Performace of MAPCHECKOUT depends on the size and/or used techniques (xrefs ...) of the underlying DWG.
I am not familiar with the CAD-specific techniques (xrefs ..) which may contain a dwg. What could be causing the delay?
Hello
Could you insert your XREFs as a Block to do a test ?
Then PURGE your DWG twice ...
So now you have a DWG without any XREF ...
Record it with a NEW filename
Quit MAP , Re-Enter MAP
Does'it make a difference ?
Bye, Pat
PS: have you installed the SP1 on your MAP 2013 ?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20567715&linkID=9240858
Patrice BRAUD
SP1 will be installed the next days by our IT department.
I talked with your CAD-colleagues:
- The large DWG does NOT contain XREFs.
- The dwg contains a lot of blocks (some with block attributes). All blocks are stored in the DWG.
I used PURGE.
I think the problem are the blocks. I deleted all layer with blocks: now it is fast.
I will investigate whether there is a certain layer with blocks which is causing the problem.
