AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
SHP output in radians? Needed in degrees
7 REPLIES 7
Message 1 of 8
750 Views, 7 Replies
I'm a new user of AutoCAD Map. I have a map that I want to export as .shp but I'm having a problem: The data in the 'angle' column of the table, which in my original drawing is in degrees, appears to be in radians in the exported file. Is there any way that this can be fixed?
Thank you
7 REPLIES 7
Message 2 of 8
Pointdump
MNC,
I've never seen Lats and Longs in Radians. Would you please post your data?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 8
in reply to: Pointdump
Thank you for your response. My map consists of a set of walls from an archaeological structure. The column that shows the error is meant to be recording the values measured from the geographical north (360º). Prior to export, the values recorded in the drawing were in the correct format. I'm attaching a screen cap of a single wall with the data table displayed below showing the issue. I'm new to Map so perhaps there's something obvious I'm missing...
Thanks again
Message 4 of 8
Pointdump
MNC,
What do those values look like if you expand the column widths?
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 8
Here it is.
Thank you
Message 6 of 8
Alfred.NESWADBA
connect to your SHP using _MAPCONNECT.
Then use to create a calculated field with (ANGLE / 180 * 3.14159) ... command _MAPDEFINECALCULATION
Export your SHP as SDF and now you have both angle-types in your dataset, degree as well as radiant (If you need SHP you just need to convert the resulting SDF to SHP)
The export is necessary to make the calculated field (which is only visible in the drawing) to a fixed datafield in the dataset/file.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 7 of 8
O_Eckmann
when exporting to SHP via MAPEXPORT command, instead of juste selecting .ANGLE as property to export, you can modify to convert radian value to degree by replacing .ANGLE with (/ (* 180 .ANGLE) 3.14159)
Olivier
Olivier Eckmann
Message 8 of 8
Alfred.NESWADBA
in reply to: O_Eckmann
Wow, didn't know that this field could be overridden by LISP formulas.
Great, thanks for sharing that!
- alfred -
Alfred NESWADBA
