- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have to bring as a block some shape-files and also have some of the attribute visible. I have created 2 blocks, 1 for the points and the other one for the poly-line. Everything OK with the points, Bring them using map import and will brig me the blocks. For the poly-lines I bring them as normal but I also need to show some info as block( that could also be extracted/imported). I run in Q.G.I.S. Points along the lines command and it will give me a point in the middle of the poly-line with the attributes of the line, saved this as shape file and bring it to Auto CAD map as blocks, it will show me that 153 objects have been inserted. When I use zoom extend I can't see them, if I select similar I see them( block reference). If I press select all I see that are there but are not visible? from where i stand i am bringing 2 types of points, one is working perfect and the other one not. Thanks a mil
