05:33 AM
- Mute
- Permalink
- Report
I would have another two questions about shp import.
I have two shp point files wich i want to import in the same dwg as blocks. Both shp file has the same OD called "Type". Both shp files have two value for these "1" and "2". I want to assign different blocks for all four variations. But since they are called the same, i cant have blocks with the same name.
Is there any way to make autocad differentiate the 2 shp files?
The other question is is there any way to annotate the drawing like this: If the OD is "1" then the notation text shouldnt be "1" but for example "concrete".
