10:47 AM
I thought I posted this before, but apparently something went wrong because I can't find it.
I recently upgraded to Map 3D 2020 and I'm finding the new Blocks Palette to be quite a bit cumbersome to use and would like to know if there is a way to revert the Insert Block icon back to the classic insert. I've searched online and on these forums and the only thing I can find is to set an alias for "I" to trigger the "CLASSICINSERT" command. I can't find anything as far as whether or not there's a setting to change the actual Insert Block command in the ribbon to "CLASSICINSERT".
Thnaks
