Setting to revert Insert command back to classic insert?
I thought I posted this before, but apparently something went wrong because I can't find it.
I recently upgraded to Map 3D 2020 and I'm finding the new Blocks Palette to be quite a bit cumbersome to use and would like to know if there is a way to revert the Insert Block icon back to the classic insert. I've searched online and on these forums and the only thing I can find is to set an alias for "I" to trigger the "CLASSICINSERT" command. I can't find anything as far as whether or not there's a setting to change the actual Insert Block command in the ribbon to "CLASSICINSERT".
Thnaks
pendean
Community Legend
Community Legend
you need to replace that Ribbon button with a new one that calls the CLASSICINSERT command.
bham4ever
I inserted a new icon for CLASSICINSERT command on my toolbars.
The new block insert sometimes doesn't let you redefine the older block in the drawing.
But using the Classicinsert does.
"Never say Never"
