AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Setting the label size for multiple thematic rules,
1 REPLY 1
JamaL9722060
973 Views, 1 Reply
I couldn’t figure out how the label size can be set for multiple thematic rules in one go (attached).
Thank you
Best
Jamal
Jamal Numan
1 REPLY 1
afaik you can't modify them in one step after you already created the thematic map,
but when you create the theme you can set the size that is to be used for every single style-item ... look to the screenshot.
 - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Technology Administrators
