Hi Damon,
I haven't done anything with cloud offerings from Autodesk. I just looked at their website:
"Desktop to web to A360
Store AutoCAD software drawings, project files, and map drawing files in an easy-to-access online workspace using A360. View and edit your designs online or on your mobile device, and share and collaborate easily with others. The AutoCAD WS web and mobile application for AutoCAD enables you to view, edit, and share DWG drawings and GIS maps online using A360."
"http://www.autodesk.com/products/autocad-map-3d/features/all/list-view"
As it mentions "GIS maps" I assumed you could somehow upload a GIS map but maybe using a specific command in Map which makes sure that GIS data is properly published. But I cannot find anything regarding GIS data (such as attached SHPs) in Map online help (for latest release 2016).
So, I do not know if publishing / sharing maps with A360 is possible right now if the map has SHP or other GIS data attached (via FDO).
Now I realize that I misunderstood you the whole time and, reading your posting again, I see how the process is. You just use Google drive for sharing. But how do other people view/use the files - which "viewer" or "application" do they have?
So, for me it looks like I have mixed up a few things - sorry for that.
a) data sharing with external users
Currently via Google drive but Gis files (SHP/SDF) are missing. I don't know how the recipients actually use the drawings you provide - but here are 3 options:
Solution 1 - use etransmit to include SHP/SDF files as well (there is the challenge to handle file paths settings - but this can be solved), but this solution requires that the people you provide the files with have AutoCAD Map as well (or Civil for that matter)
Solution 2 - if the recipients do not have Map/Civil create DWF files as suggested by Alfred (recipients need to be able to open DWF files)
Solution 3 - if DWF is not an option, export your drawing to plain CAD using Map command: maptoacad
b) viewing the files on tablet/phone etc
Not having looked into A360 I can only guess right now that you can upload drawing files and then they are available via a web site. That probably doesn't work if you have GIS data attached (as mentioned above) but then you could probably achieve it this way:
- export your GIS map as plain CAD drawing (maptoacad)
- create DWF file (I suppose you can upload DWF files to A360)
- set up a web GIS solution using Infrastructure MapSever/MapGuide OpenSource (most complicated solution)
Hopefully I have understood your requirements and maybe the suggestions above will help you
Rob
