Select objects with same OD table
franc_as
Message 1 of 11
franc_as
My Autocad Map 3D don't allow me to delete specific OD table. Obviously, there is an object containing that OD table.
How can I find and select all objects with this OD table? Maybe a lisp?
Replies (10)
Message 2 of 11
braudpat
Hello @franc_as
Please the DWG (or an extract with WBLOCK)
If Extract with WBLOCK, check that the DWG you send, has the same problem !
Which name for the OD Table ?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 11
franc_as
I don't understand what do you mean.....what Wblock,  what dwg?
This is common question...I just want to find all objects in any current drawing, which contains (if) OD table (for instance) named TEST.
And I want to stay them selected after command finished.
Lisp routine would be fine.
Regards
Message 4 of 11
braudpat
Hello @franc_as
1) OOPS SORRY : OK you have not a specific problem with a specific OD Table !
2) When I want to find ALL Object (on ACAD MAP or ACAD CIVIL) with a specific OD Table,
I am using the famous Lisp/VLisp routine "Sel_By_OD" (from @CADaSchtroumpf) BUT with a curious / abnormal method !
3) Load the routine with  APPLOAD  Command then  "Sel_By_OD"  <Enter >
and Select ONE Object with the famous OD Table
and then select and do an "impossible" Test on an OD Field !
THEN you get ALL Objects of your DWG with the famous OD Table !
For example 1 : you have an OD Integer/Float Field with a positive value, test with Value /= (Different) -1
For example 2 : you have an OD String Field with many values, test with Value /= (Different) ZZZZZZ
Do you see, that I Mean ? ... Is it OK for you ?
Bye, Pat
Patrice BRAUD
Message 5 of 11
franc_as
Thank you, but I already have this Sel_By_OD lisp.
But in this case not working... you must pick (only) one object with this OD table first.
But I dont know which object contains this OD.
So imagine, if you have to pick among thousants of objects to find it...
Message 6 of 11
franc_as
The only solution is, to make new object and append my OD table to it.
Then run Sel_By_OD and select new object......
But I wish a simple, quicker way.
Regards
Message 7 of 11
braudpat
Hello @franc_as
YES it is a "correct" Solution (2-3 seconds to create a Circle/Line, then 2-3 seconds for ADEATTACHDATA, then Sel_By_OD, ... wait for the result ...) !
Happy WE, Bye, Pat
Patrice BRAUD
Message 8 of 11
braudpat
Hello @franc_as
An other beautiful Lisp/VLisp routine from @CADaSchtroumpf !
The routine "ODYesNo" could interest you !?
It will find automatically Entities WITH or WITHOUT OD Tables !!
Happy WE, Bye, Pat
Patrice BRAUD
Message 9 of 11
franc_as
Yes, I have already know and use this Lisp, and some more from @CADaSchtroumpf..
He is great...
Message 10 of 11
O_Eckmann
Hi @franc_as ,
If you can install a plug-in, you could use mine : https://apps.autodesk.com/MAP3D/fr/Detail/Index?id=7146835859656784994&appLang=fr&os=Win64
Here is a video to solve your problem.
(view in My Videos)
Olivier Eckmann
Message 11 of 11
franc_as
Great tool, works perfectly....Thank you!
