01:49 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to make a script out of two commands: First mapconnect and then mapimportfdo.
Problem 1: Mapconnect doesn't seem to care about the filedia or attdia-parameters. Even if both of them are zero I still get the dialog box to choose data connection. How do I do this at the command line instead?
Problem 2: With mapimportfdo the filedia-parameter works fine, but at the command line it doesn't recognize the names of my data connections. In fact, if I try to list available connections there are none in the list. But I do have connections, if I use the dialog boxes it's okay. Is this a bug or what am I supposed to answer at the command line?
I'm working with Map 2010 and using ArcSDE connections.
AC
AC
