I'm new to AutoCAD Map 3D and working on the electrical equipment on some maps. I use the already defined SQLite class objects from the Industrial-Electrical NA template for objects such as fuse, substation, service point, etc. The class objects and layers are shown in the "Display Manager" window. The objects come with a fixed base point and angle. For instance, the fuse from the industrial template is default with 0 degree but I want to rotate it to 90 degree. Therefore, when I try to rotate or scale them by ROTATE, AutoCAD Map 3D won't allow me to do so. I've been searching for solutions from AutoDesk Help Website and other relevant posts but they seem do not work for my case. I'd appreciate any help to solve this problem.
