REVCLOUD COMMAND
REVCLOUD COMMAND
pedram.samieyan
Observer Observer
REVCLOUD COMMAND
pedram.samieyan
Observer
Observer
Is there a way to change REVCLOUD default from Freehand to Rectangular?
I use REVCLOUD command a lot and its Rectangular option is the most favourite one. However, every time that I call in the REVCLOUD, I have to type R or click on Rectangular button to activate it. So wondering if there is a way to make the Rectangular option as the default of my REVCLOUD.
Thanks in advance for your advice.
P
O_Eckmann
Hi @pedram.samieyan ,
How do you launch REVCLOUD command ?
- from ribbon
- from toolbar
- from menu
- from palette
- from shortcut on keyboard
According to your process, solution could differ.
Olivier
Olivier Eckmann
fieldguy
as @O_Eckmann mentioned, it depends how you access it.  you can set the "REVCLOUDCREATEMODE" system variable to 1 in your template (dwt) file but that value will change whenever you select "Freehand" or "Polygonal".
from help
REVCLOUDCREATEMODE
0 (Freehand)
1 (Rectangular)
2 (Polygonal)
if you want to force it to 1 every time you click a button somwhere, you need a custom solution - lisp or macro are not too difficult.
"REVCLOUD" is not specific to Map.  You should enter that search term in the >>AutoCAD Forum<<
pedram.samieyan
Observer
Observer
THANK YOU VERY MUCH!
pedram.samieyan
Observer
Observer
THANKS!
