do you know if there are some printer settings within the Report Designer of Infrastructure Administrator?
I see the print/HTML/Text/PDF Button but I do not see where I can change settings like
Do you know where and if I can configure these things in the background somewhere?
Best regards,
Peter
Hi Peter,
I think these bits are missing. I guess Map has its internal PDF library - and the report engines uses just that.
I wasn't aware that there is an issue with printing colours - at least when printing to PDF I would have assumed it is printed with colours?
We have a few (simple) Map based reports, the more complicated ones have been implemented with CR and are run through web based GIS.
Rob
Hi Rob,
could be possible with the internal PDF Library.
No, there is no problem with printing colors. I just hoped that I would like to configure general printing options like
Do you know how I can find out if there is an internal PDF Library?
Peter
Hi Peter,
I looked at the Map IM API docs and did not see any PDF related classes.
So it doesn't seem to be exposed.
Rob
