AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
rename multiple blocks
34 REPLIES 34
Message 1 of 35
2874 Views, 34 Replies
HI TO EVERYONE
i am still looking for a simple lisp to  rename multiple blocks at once in the same drawing
i mean different block names to one name
any ideas?!
34 REPLIES 34
Message 21 of 35
in reply to: АлексЮстасу
where do i find this tool MAPEXPORT all blocks with an attribute ?
i am using autocad map3d 2015
i also attached the file
Message 22 of 35
where do i find the MAPEXPORT all blocks with an attribute
Message 23 of 35
АлексЮстасу
See your image.
Or you can write at the bottom of the AutoCAD window on the command line: MAPEXPORT.
(MAPEXPORT, MAPIMPORT - AutoCAD commands)
The format is not important. I like mif / mid - text, can be manually corrected. Many people like shp more.
Export - specify the necessary blocks:
Import - specify one block:
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 24 of 35
i cant select create as blocks
it wont let me
Message 25 of 35
АлексЮстасу
There should be a block description in dwg. For example, copy the block you want in dwg and delete.
Message 26 of 35
ok it worked but......
still it changes the text in the blocks into one
i need the text in each block to stay the same
Message 27 of 35
АлексЮстасу
Have you enabled Get attribute values ...?
Message 28 of 35
now it workeddddd
finally
just one last thing
it changed the blocks geometry from 0.25 to 1
what can i do to keep it as the way it was?
Message 29 of 35
Barzdil
hello, are You talking about block scale?
Message 30 of 35
in reply to: Barzdil
Message 31 of 35
Barzdil
there are variuos Lisps to change block scales all at ones. Another way is to use command "adequery" with "alter properties" to do the same action. Again, both methods You can use with creating Your command macros routine via command line method, so in the final result You will have to press just once, and all Your blocks will be changed to right block names with right 0.25 scale.
Message 32 of 35
Hello. This ispt renaming blocks by matchinh the direction. I need to keep current direction of blocks . How can i modify it ?
Message 33 of 35
ispt - ?
Please clarify the task.
Message 34 of 35
I mean this script.(Lisp Code).
For example my blocks like this and assume that all of them have different block names
After i use the lisp block names became same but directions have changed. I need their directions remains the same
Message 35 of 35
Try replacing blocks using Query in MAPWSPACE.
I'm sorry, but I don't have an en-AutoCAD right now.
Technology Administrators
