Publishing layouts with attached WMS map - not refreshing map before print
igor.horvat
igor.horvat
Hi there,
I have a problem when publishing multiple layouts with WMS underlying map.
When the publishing is done the map on the pdf is not refreshed to current zoom and it prints blured. If I print one layout at the time the map have time to regen and than it prints correctly. But I want to save time and print all at once so maybe you know where is the trick to print multiple layouts.
Thank you in advanced
P.S.
I'm using this WMS server https://geoportal.dgu.hr/wms?version=1.3.0   no login is public
ChicagoLooper
You are correct. It takes time for the WMS to refresh at different zoom scales. Unfortunately, the publish operation doesn't wait for the connection to focus and it prints layout-after-layout without any regards to map resolution. Since you are limited to the speed your computer can communicate with the WMS service so you'll have to print each sheet individually to achieve clarity.
Chicagolooper
