Once I got the labels to show up, I tried to grip edit / drag the label down into the view port so it would plot. It vanished instead.
How come you have a drag state for Civil 3d labels but not Map one?
I also managed to have other labels vanish as I tried other convert to text and other functions.
Connect to shp file with Map
style manager - remove fill, change line color, add label with function to concat multiple data fields into one label.
Have label show up at centroid location. Try to select label to move it. Have it vanish instead.
Civil 3d 2014.
I tried the Map convert label to AutoCAD text, but the text still shows up as a function in the map workspace. If you uncheck, it vanishes. I finally managed to WBLOCK it out to another file. But not all the database objects had labels. It is a start.
