I am attempting to migrate profiles (*.arg files) from AutoCAD Map 3D 2014 to AutoCAD Map 3D 2020. The Knowledge Network article on the AutoDESK Migration Utility does not appear on my start menu as advertised in the article.
I've been struggling with this for two weeks now and I'm thoroughly frustrated. Please Help.
Thank you,
J Edward Leavitt, PLS
Land Surveyor, PLSS Dataset Manager
Department of the Interior, Region 8/10
U. S. Bureau of Land Management
Branch of Cadastral Survey
2800 Cottage Way W-1623
Sacramento, CA 95825-1886
916-978-4347
Sorry, but I'm a little rusty when it comes to arg. You are trying to move your profile from v2014 to v2020, correct?
I don't believe you can do that with arg. Although you can migrate form same-year to same-year, e.g. from old computer to new updated computer, you can't migrate from old version to new version using arg.
You can read this Support Article (dated 5/2/2022) addressing your issue.
Note: the article mentions certain conditions that must be present for the workflow to succeed so the solution provided may not apply to your specific situation. Good luck.
