Hi, I'm using AutoCad Map 3D 2019. My knowledge of AutoCAD is very weak so please excuse me in advance for my lack of understanding.
I have hundreds of separate DWG files that make up parcels of land inside of a county. I would like to be able to merge each of these DWG files into one and export them as a shapefile. I have tried to use the XREF command and then export to shapefile, however when I open the exported shapefile it has only exported the original DWG and not the XREF's. The same thing happens if I Bind or insert the XREF's. I'm not sure what I'm doing wrong, but I've exhausted everything I can fathom to get this to work and I'm done trying to figure this out on my own. I feel like there has to be a simple answer to this problem.
DB
