Message 1 of 8
MAPTRIM does not trim some entities
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Using AutoCAD Map 3d 2014 (could be 2015) I want to trim the entities of a drawing based on a contour (the contour is a closed poliline in a locked layer).
All seems to be OK, but there are some entities that are not correctly trimmed or are entirelly removed (having a part inside the contour.
In the attached drawing is a sample and those are my steps:
- Run MAPTRIM
- Select contour (the rectangle)
- Let the automatic selection (it should trim the green line)
- Trim entities outside the contour
- Ignore untrimmed objects
Once the command finishes, remains part of the green line outside the contour... Can anyone tell me why?
As I can see, the TRIM and EXTRIM commands trim the line perfectly, but as I have to use Object Data, I cannot use them.
Thanks for your help in advance!
Luis Alberto Manero, Geograma.com
