- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've got a client who uses Map 3D 2020 and Civil 3D 2020. Both software are fully updated. Each software is installed on two separate computers for two separate users.
They want to use the MAPEXPORT command to export a file out to KML format. They initiate the MAPEXPORT command and go through the process. . .
- file type = kml, kmz
- file name given
- all objects are selected
- object properties are set
- coordinate system was set prior to the export tool
When the user clicks OK to save the file out it appears as though it saves and is complete. However, the file cannot be found anywhere. I verified the directory and tested a few times with the same results.
We then tested the same process but tried to export out to a SHP file with the same results with the same outcome.
It's not a file issue because we tested in an existing drawing, a new drawing, and one from my computer. All had the same results.
I then tested on my computer in Civil 3D 2020 and Map 3D 2020 and it worked fine for me (same build as my clients).
Any ideas?
ASTI Civil Solutions Technical Advisor
www.asti.com
