Trying to create a Map Book with a template I have already created. However AutoCad will not recognize my template's title block. This is how I came across the error:
-Went to task pane.
-Clicked Map Book.
-Right Clicked on New >> Map book.
-Clicked Sheet Template.
-Clicked "..." to select my template.
-Used Drop down menu to selected Layout.
-Under Layout options.
-Checked "Include a title block."
-Used drop down menu to select the block I had made in the template.
-Set Scale Factor to 100.
-Set up Tiling Scheme and Naming Scheme how it normally works for me.
-Set "None" for Legend and Key.
-Set "Create New" for Sheet Set.
-Clicked Generate.
-Following Error message pops up: "Invalid Setting Found, Template layout does not have title block specified."
What did I do wrong?
