James,
You've got something odd going on with your version of Map. These commands
definitely work on the 3 computers that I've tried with the COGO Commands.
Do you have some other software or program runnning with Map that could be
appending the ,0.0 on the end?
Try going to the COGO setup command (MAPCGSETUP) and disable the option for
3D input. It didn't change the things work on my computer, but it might help
you. If that doesn't help, you need to do some detective work on your PC.
Cheers,
David
"James Solberg" wrote in message
news:3BA624650DE835941F52E81F1F7D0EEC@in.WebX.maYIadrTaRb...
> No help. This does not work. Here's the result from the command line;
> Command: pline
> Specify start point:
> Current line-width is 0.0000
> Specify next point or [Arc/Halfwidth/Length/Undo/Width]:
> Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: 'ad
> Enter angle:
> Specify distance:
> "@80.711706<342.8087052495,0.000000"
> 2D point or option keyword required.
> Apparently the COGO input passes a Z coord to the pline and arc commands,
> which they will not accept.
> Jim
> "Mark Christian" wrote in message
> news:C0D237C410566035A269DEA114743998@in.WebX.maYIadrTaRb...
> > Hello james,
> > Enter pline on the command line and draw a pline. Then type one of the
> COGO
> > commands, such as, 'ad. Hit enter. Select your angle and distance and
> then
> > draw another pline, selecting another of the COGO commands if you want
to
> > draw via geometry, etc.
> > I hope this helps.
> > Regards,
> > Mark Christian
> > GIS Product Support
> > Autodesk, Inc.
> > news:32AA095A7CD1AE67ACB61F541FAE40BB@in.WebX.maYIadrTaRb...
> > > The help files seem to indicate cogo input can be used when
constructing
> > > polylines and arcs. This does not work for me. I can only construct
> lines.
> > > Anyone have the same problem or solution?
