Hello from France
+0.5 with gluckett
AutoCAD MAP is very popular in France but its market is decreasing slowly every year mainly because of QGIS and lack of NEW features !
Sorry but Autodesk hasn't add any valuable features to MAP since MAP 2012
*** MAP 2012 ***
New FDO display/labels engine & TopoBase Models integration (Water, Sewer, Elec, etc)
I estimate that about 10 customers are really using TopoBase Models with MAP in France ... So No Comment ...
Of course much more customers in Germany, Austria, Switzerland because in these countries, they are many good old customer of C-Plan (which has been bought by Autodesk)
*** MAP 2013 ***
A few new minor FDO features
*** MAP 2014/2015/2016 ***
Only recompilation of previous MAP with some FDO bugs corrected and very minor / micro Features ...
*** For the FUN ***
2/3 years ago, I was asked by the AutoCAD MAP team manager about NEW features and/or Corrections/Improvments, I Need ! ... I was very enthusiast ! ... So since a few years, I am sad with MAP ...
Here is my OLD wish list ... With some/many of these features AutoCAD MAP could be a real NICE product !!!
****** Improvements (or Bug Correction) on existing Features ****** Patrice Wish List ***
01) --- MPOLYGON --- Bugs / Limitations ---
01A - Add a feature Hatch Lineweight
01B - The Display of the Middle Grips is not correct (compare to PLine)
01C - Be able to autogenerate Links (UDL) to Tables with MPOLYGONs (It works only with closed PLine)
02) --- MAPIMPORT (Polygone/Surface Geometry) ---
We have an option to import all entities as MPOLYGON or as PLINE - Please keep it !
Very often we have a few MPolygon in the layer but ALL are MPolygon after MAPIMPORT ...
(or every geometries are closed PLines after MAPIMPORT)
Please offer a NEW option : Create MPOLYGON only if necessary
So most often we get a few MPolygons and many closed PLines ...
NOTE: I have a Lisp routine for this Wish !
03) --- MAPEXPORT --- MAPINFO Format ---
Please could you set the correct MapInfo settings relative to system coordinates
when doing a MAPEXPORT with the TAB and the MIF-MID format ...
04) --- ATLAS --- BUG with Scale + Polygonal VPort ---
Please correct the beautiful BUG on the scale which is FALSE asap with we have a % overlay/overlap
Please add the possibilty to have a polygonal vport (not ony rectangular) for the main vport
****** NEW Features for MAP ******
01) --- Object Data General and EDIT ---
01A - Be able to rename an OD field/column
01B - Be able to reorganize the order of fields/columns (up/down)
01C - Please a function like Search and Replace ODs
01D - Add Prefix or Suffix on alphanumeric ODs
01E - Add or Multiply by a value for numeric ODs
02) --- Object Data - Select, Query, Update, etc --- in the CURRENT drawing ---
Be able to see OD as a Grid (idem the Attributes Tables with FDO)
Select, Query, Update, Export as CSV, etc
With options : auto-select, auto-zoom, etc
Be able to use a QSELECT on OD or something equivalent ...
NOTE: I have a Lisp routine for search and select from an OD value !
03) --- MAPCLEAN ---
We have "Cut at intersection" of lines, plines, etc
Please I would like a NEW option : "Cut at Block"
So for each Block selected which is ON a line, pline, etc : the line, pline, etc will be CUT at the Insert Point of the Block
Please keep XDATAs and ODs on each part of the line, pline, etc ...
04) --- Drawings Group ---
Be able to use Query with Properties Updates and Reports INTO the Current Drawing
Very important : it's too slow to use a New DWG and then we have to associate THE drawing and then execute many Queries ...
Then Save the DWG, Quit, Reload, etc
05) --- FDO Gis Overlay ---
05A) We have Lines intersected (or other operations) by Polygons
But I need : Polygons intersected (or other operations) by Lines
06) --- In the past, MAP 2005/2006 have some features of CIVIL : points, surfaces, etc ---
In MAP, I need to be able to manage points (External CSV Points or ACAD points or ACAD blocks)
to generate a 3D Surface (3D TIN - maybe explode it to get many 3DFaces), generate 2D Plines at Z/Elevation, and colorize 3DFaces depending on the Z/Altitude or the Slope, etc
--- It's THE MINIMUM for a GIS Software ---
I don't speak about Profiles and all other high levels features of CIVIL ...
07) --- TIF+TFW, ECW, JPG+JGW on a 3D Surface (3D TIN) ---
Be able to use this kind of images on 3D Surface with 3DOrbit, etc
AND please a GOOD quality when printing the 3D Drawing + Images
In the past your ENVISION product was doing this job nicely !
08) --- Google Earth Plugin ---
It's a MUST for me because we are speaking of a GIS Software
For example you could implement only MAPIMPORTKML/KMZ and MAPEXPORTKML/KMZ
with the possibility to IMPORT/EXPORT attributes NOT ONLY Geometries !
09) --- FDO Printing with Raster ---
Please could you IMPROVE the quality of the FDO printing especially when we have Raster Images !!
10) --- FDO Clipping with Raster ---
Please could you implement the clipping of FDO Raster (idem that we have with standard Raster File)
11) --- Export FDO Map to DWG ---
Please add a NEW option to export FDO attributes as Object Data of MAP (or CIVIL)
The option to export the FeatureId of the FDO Layer as XDATA is usable only by programmers ...
12) --- FDO Geometry + FDO Raster + DWG Layer + DWG Raster + etc : BUG !? or Improvement !? ---
For me, there is a major bug when we mix FDO, FDO Raster, DWG, Raster DWG, PDF, DWF, etc
The bug is related to the display/printing priority which is NOT STABLE !
Could you propose something easy to use and manage ?
13) --- FDO : Add more options to control the display (or NOT) of FDO Labels ---
13A) Always Display (Yes/No) - Very important: it's my problem if I have many many labels/texts ...
13B) Display (Yes/No) if no overlay/overlap with an other label/text
13C) Display (Yes/No) if no overlay/overlap with a geometry (line, polygon). I speak about the vector graphic not the hatch
13D) Display (Yes/No) if no overlay/overlap with a hatch (coming from a polygon).
Something relative to 13B/13C/13D wish : be able to give a Radius to find somewhere a "free" seat for the text/label if possible !
14) --- Linking Polylines to DataBase ---
An easy way, to link automatically (UDL, etc) many PLines with ODs (with a FeatureId field/column) to a existing Table (with the "same" FeatureId field/column)
15) --- FDO Driver for DWF with attributes --- Read Only Mode ---
Because with a high precision DWF (+ attributes), we could use it as a FDO Layer ( no action on stylisation but I need the Labels ! )
So NO USE of a DWG !
16) --- FDO Attributes : EDIT ---
16A - Please a function like Search and Replace Attributes
16B - Add Prefix or Suffix on alphanumeric Attributes
16C - Add or Multiply by a value for numeric Attributes
17) --- FDO General --- Read-Only Option (Yes/No) = Security ---
For Geometry FDO Driver : SDF3, SHP, Oracle, PostGIS, SQL Server Spatial, SQLite, ODBC, etc
Please add an option into the connect FDO dialog box (when we see all available layers)
Read-Only (Yes/No) - Default = No
18) --- MAP ODs with AutoCAD Fields ---
The "Insert Field / Object" Feature of AutoCAD (coming with AutoCAD 2005/2006) can't see the ODs of MAP
I will appreciate tu use ACAD Fileds with my ODs ...
19) --- Break / Trim / etc ---
These ACAD commands erase the ODs !
For example, if I break a Pline with ODs, only the first part of the PLine will keep the original ODs !
NOTE: I have a Lisp routine for breaking Line, Pline, etc and keeping OD value !
SNIFF, SNIFF, I had a Dream !!!
Regards, Patrice (I am not an Autodesk Advisor)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
