Map 3D 2006 incompatible with Windows 7 pro
After installing Autodesk Map 3D 2006 on a new Dell Precision 5510 Windows 7 Pro laptop, I can't run it. I get an error that says the program is incompatible with this operating system. There is another Win 7 Pro laptop in the office that is running it ok. Any tips?
antoniovinci
No tips there, sir.
I bet on that laptop Map2006's working within a virtual machine, so try the same way on your computer.
Alfred.NESWADBA
Right-click the desktop icon for your Map3D-start ==> properties. Within that dialog change to tab "compatibility" and try different older releases of Windows ... also make that tests with admin-permissions, because it could be an issue of permissions too.
Good luck, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
O_Eckmann
Map 2006 is based on .Net Framework 1.1 which is not part of Windows 7.
Verify on your working PC if it is installed.
If yes, try to install it : download is here
Olivier
Olivier Eckmann
