AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Map 2012 Enterprise - File database with SQLLite
4 REPLIES 4
369 Views, 4 Replies
Hi
I am using Autodesk 3D Map 2012 Enterprise. I used Infrastructure Administrator 2012 to create a File based schema with the required tables and domains. This has created a DWT file and my understanding is if i create a DWG file using this DWT as the template then i should be able to create the features with the attribute details stored in SQLLite. I am also not very clear whether this SQLLite would be embedded within the DWG.
I have an Utility network asset map of a city with OSMM background and Address Layer 2 in UK which i want to transfer to a DWG file created in this template. The source data is a ESRI filegeodatabase format with data held in 30+ featureclasses. I can convert the featureclasses into SHP files.
a)My problem is how can i import the contents of the shapefile into a DWG file created using the template defined using Infrastructure Administrator 2012 above and indicate that the attribute should go to SQLLite or is it something implicitly handled ?
b) It leaves me wondering as why Autodesk is not stressing on the adoption of SDF which is projected as a DWG with relational datatables? What is the intended use of SDF?
Thanks and Regards
Govindarajan
4 REPLIES 4
NateMoore
It sounds like Project Parsec (http://labs.autodesk.com/utilities/parsec/) might be what you are looking for - it'll allow population of a file based Industry Model from .shp (and maybe even from geodatabase if you are on 32 bit and have an ESRI license available).
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
Alfred.NESWADBA
in reply to: NateMoore
Hi Nate,
just if I missed something, but your link points directly to a text:
        Project Parsec does not work with AutoCAD® Map 3D Enterprise 2012
What to do now? What info is now wrong?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
NateMoore
in reply to: Alfred.NESWADBA
You should have a "Download Now" button in the upper right.  It downloaded for me, though I haven't tried it yet...
Nate Moore, GISP
Global Services
Autodesk, Sarl
Thanks for your answer i will try this tool and get back to you.
”Boost
