Hi I've had this problem for a while and never found a solution or took the time to ask for help.
I am using AutoCAD Map 3D 2013 SP 2.1 64 Bit Windows 7.
When I am in Layout space if I have a rotated view that is not World View my labels for SDF and SHP files disappear. Is there any solution to this?
I have tried 2 methods of rotating the view, one is UCS customizing with a PLAN view oriented to the current UCS. Labels disappear.
The other method is DVIEW and TWisting all my features N degrees. Labels disappear.
I usually end up making labels for the few things I need labeled but this time it covers a large area.
Any help would be much appreciated, thank you!!
