AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
LISP for naming mapbook tiles
0 REPLIES 0
Message 1 of 1
As-Built_Sigurd
348 Views, 0 Replies
Hi all,
When I create a Mapbook and use manually selected tiles, there doesn't seem to be much functionality in the naming. Just gives "foward" or "reverse". It seems to often give a weird naming convention, the first one I did it started in the middle of the area and went from there. I've attached a screenshot to show what I mean.
I think if someone could please show me a LISP routine, I think it would be pretty simple, which inserts sequential numbers into the object data (Sheet_ID) attached to the polylines I have created? I can then use data driven naming from the object data. Convention would be left to right, top to bottom. Anything would be better than attached though!
Labels (2)
0 REPLIES 0
Technology Administrators
AutoCAD Beta
