Hello!
Who can help me? I want to creat a line style for feature objects (line object) wich symbols only on the vertex of the line. How can I do it?
Solved by parkr4st. Go to Solution.
one way shown in the attachments. is this for display only or some other reason?
How I did the display manager. two uses of same shp file #3. and with the line work layer off #4.
You could also get the nodes at the ends of lines as points and style the points in a seperate layer.
dave
Thank you, parkr4st, for to try help me!
But I don't want to creat seperate layers. I want to do it only on liner layer. An example, I want to creat a power trust which was shown on the picter. I can to make a liner layer which symbols (blocks). But in AutoCAD Layer Style Manager we can do it by giving interval between symbols. If I want to give a symbol only for the vertex of the line, it is impossible. Have any way to creat style like that?
No, this method, which you show, inserts the symbol only to the start and end vertexes. But I need to insert it to all vertex
But I thing that is not normally cartographic method. Because, every power trust must be one whole polygonal object and one raw in database table. Thank you very much, parkr4st, for trying to help me. I understand that in AutoCAD Map have not cartographic (styling) function like that......
Oh, excuse me, please! I am sorry! I have wrote term wrong.
I want to say "truss". I speake about an elecrtic power truss (metallic construction for electric lines or tower):
bingeomatics wrote:Hmmm, I thing it is impossible what I want to get......
Did you try what advised in the post 27-08-2012 11:48 AM ..?
Yes, I did. But this your method, inserts the symbol only to the start and end vertexes of the polyline feature. But I need to insert it to all vertex..... The problem in that...
bingeomatics wrote:inserts the symbol only to the start and end vertexes of the polyline feature
The end, sir.
Thank you, antoniovinci, for trying to help me! Don't trouble in this problem. Because, I understood that it is impossible in AutoCAD Map. I can't use your method, because you offer about drawing objects. I can't apply they to my spatial feature classes (digital map). But for all that thank you very much, for all informations.........!
