AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Layer State not applied 2014
1 REPLY 1
frosty1_4me
421 Views, 1 Reply
I have a drawing that when I open it has a layer state that is saved against that drawing.  If I view the layers in the layer state manager it shows what I expect to see the layers setup as with the correct layers frozen or off.  However, those states are not being applied to the dwg.   I have also tried importing a .las file which has the same layer states but it too does not apply the layer states to the dwg either.
Is there something I am missing with this layer state function?
When I first open the Layer state manager I also get this strange message:
After that message when I view the layer state manager there is now a new layer state listed called LMAN_ACET-LAYISO which is applied to the model space.  It does not have the layerstates that are in the setup that is saved against the dwg which is what I want applied.
Can someone shed some light on this?
Thanks.
1 REPLY 1
pendean
in reply to: frosty1_4me
Create a new one, it's quicker. Then test it in other files and see where it's breaking.
LMAN is dead and the 'automatic' conversions don't really work.
Technology Administrators
