- Mute
- Permalink
- Report
...is there any way to launch Google Earth to the point I pick in AutoCAD Map 3D 2016???
This is awesome and very helpful, thanks for sharing!!!
this is very cool, works fine in civil3D 2017 for Belgium
thank you for sharing this!
It works in Switzerland too, with Map 3D 2014 and 2018.
Thanks Pat!
Kind regards,
Hello Seb
Thanks for Kudos, Happy WE, Regards, Patrice
Patrice BRAUD
In Russia, too, works.
As everywhere, if CS is installed, of course. 🙂
I do not know why my message was marked as a solution!
It happened by chance!
How to remove it?
Alexander,
I "un-Solutioned" your post.
Dave
Dave Stoll
Las Vegas, Nevada
@braudpatwrote:
Hello from France
Welcome to the Autodesk / AutoCAD Forums !
In France we are using this routine "NM-StreetView" which launch directly Google Earth + StreetView
at the Point designed on the drawing ...
The routine can also launch "mappy.com" and/or "mapchannels.com" ... But I have commented the lines ...
I have always used "NM-StreetView" on DWGs with French Projections ...
Please let us know if "NM-StreetView" runs correctly anywhere around the World !?
Regards, Patrice
I like to know if you can help me to get you lsp working.
I am currently using window 10, google chrome, Microsoft edge and IE 11. All browser and os software are up to date.
Here is what I have tried.
1. Went to map 3d
2. Setup my dwg to the correct zone and coordinates
3. Create a manual point
4 Type appload in the command line
5.Next browse to where the program is saved on my hard disk
6. Menu pops up with the program and I click load.
7. Says lsp program loaded successfully
When checking all my browsers I don't see anything?
Any help would be appreciated.
Patrice BRAUD
@braudpatwrote:
Hello
Please install Firefox or Chrome...
Don't let IE be your default Browser !
Try again...
Regards, Patrice
Thanks for your reply I will give it a try on Monday and let you know.
Subject: Launch Google Earth from Point picked in ACAD MAP 201X / ACAD CIVIL 201X
Hello
Please use this routine instead !
It's the same "NM-StreetView" routine but with 2 different launches :
- data.mapchannels.com with SITE2 ...
- GE StreetView with SITE3 ...
And the 2 launches are printed on the text / command Line (F2)
So if you have a Browser problem, you can copy / paste the 2 different launches to your favorite Browser !
Results are better with Firefox or Chrome !
Don't forget to assign the RIGHT Coords System / Projection BEFORE launching "NM-StreetView" !!
( Command: MAPCSASSIGN or the old ADESETCRDSYS )
Happy WE, Regards, Patrice (The Old French Froggy EE)
Patrice BRAUD
@sebastian_meliwrote:
Greeting!
Can you help me find where to look with regards to creating a site plan with details but not like a google map attacment i.e. lines and shapes (trees,drìveways,curbs and have a scale to this) sorry for that long shopping list!
I wish I knew of an easy way to tell you, however we use either AutoCad Map3d or Civil and use the imagery (Geomaps) to trace these areas with polylines that we creat linetypes for such as "Edge of road" or roadway centerline. There are some downloadable items in our area provided by the State that have the centerlines or the parcels and you would just have to attach them to your drawing. Not sure where you can find maps for your area but try a search for Tiger maps of your area. Doubt this helped but I am sure someone will get some more help!
Need help please. The NM street view was working till now. But now gives me error as under.
Thanks in advance.
Bela
Hi Pat,
Getting this error recently when I try to launch this lsp in Autocad 2016 and 2018. Please help. Thanks in advance for your time. Was working before.
Bela
Hello
ATTENTION : this Lisp can work ONLY with ACAD MAP or ACAD CIVIL !
Have you a MAP or CIVIL ?
The Health, Bye, Patrice
Patrice BRAUD
