AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Launch Google Earth from point picked in AutoCAD Map 3D 2016
43 REPLIES 43
Message 1 of 44
dkoppes
4610 Views, 43 Replies
...is there any way to launch Google Earth to the point I pick in AutoCAD Map 3D 2016???
Tags (1)
43 REPLIES 43
Message 41 of 44
FJankovsky
in reply to: braudpat
Patrice,
I just want to thank you again for sharing this routine. I have to show locations from my map to field crews and I am using this constantly. I have created a custom menu button for it to make it even simpler. Set the LISP to load at startup and one click and you've got the Google Earth image.
Great time saver for me.
Message 42 of 44
info6XV83
in reply to: dkoppes
so do i
is it fixed yet by autodesk?
"i don t want to be a programer - i am a user"!
nob
Message 43 of 44
FJankovsky
@info6XV83
Did you get this figured out or are you looking for some help?
Message 44 of 44
vladimir_michl
in reply to: info6XV83
Fixed? It is not an internal function. But you can add this functionality through an add-on application. Besides the mentioned LSP routine you can also use the GEarth freeware utility - it works not only in Map but also in AutoCAD and even AutoCAD LT. See:
https://www.cadforum.cz/en/how-to-open-google-earth-directly-in-your-autocad-window-tip13512
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
Technology Administrators
