Launch Google Earth from point picked in AutoCAD Map 3D 2016
dkoppes
dkoppes
...is there any way to launch Google Earth to the point I pick in AutoCAD Map 3D 2016???
Replies (43)
braudpat
Hello from France
Welcome to the Autodesk / AutoCAD Forums !
In France we are using this routine "NM-StreetView" which launch directly Google Earth + StreetView
at the Point designed on the drawing ...
The routine can also launch "mappy.com" and/or "mapchannels.com" ... But I have commented the lines ...
I have always used "NM-StreetView" on DWGs with French Projections ...
Please let us know if "NM-StreetView" runs correctly anywhere around the World !?
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
dkoppes
Where can I download app ???
________________________________
The information contained in this email is privileged and confidential and is intended for the use of the addressee listed above. If you are neither the intended recipient nor the employee or agent responsible for delivering this message to its intended recipient, you are hereby notified that any disclosure, copying, distribution or the taking of any action in relation to the contents of the email information is strictly prohibited. If you have received this email in error, please notify the sender immediately by telephone or reply email and destroy this email and any attachments.
braudpat
Hello
1) The Lisp routine is attached with my previous message ! ... Please download it ...
2) Use the command APPLOAD to load the Lisp routine ...
3) Then on the keyboard : NM-StreetView <Enter>
Regards, Patrice
Patrice BRAUD
Murph_Map
Regards, Patrice
It works OK here in Tennessee, USA.  Nice and quick at that.
Murph
Supporting the troops daily.
kajar
Working well in Estonia.
Kajar
dkoppes
It works great!
I wonder why Autodesk does not incorporate this into MAP 3D???
...also why not add Geocode to...
Seems like a MAP application should have these features built in...
Thank you so much, if your ever in Atlanta drop me a line and I will buy you a beer...
See ya!
Don Koppesetic
kajar
Autodesk just  offering platform for you.
You can use lisp for creating  almost everything you want to use in Autocad.
Kajar
dkoppes
Hey Guys,
Koppesetic calling you from Atlanta, Georgia,
This is a great routine, but I am having problems with the mouse wheel zooming in too close or zooming out to far on the maps..
How can I launch Chrome instead of IE 7 ?
Thanks in advance for your time !!!
nwray
Regards, Patrice
Works great in California!  Thanks for posting this!
Norm
GIS Specialist
BOXX Technologies APEXX 2 2402 Workstation
Intel Core i7-6700K @ 4.4 GHz
32 GB RAM / 500 GB SSD
NVIDIA Quadro M2000 Graphics
Windows 7 Pro 64 bit C3D 2017
nwray
When I tried it out it launched in Firefox, which is my default browser.  I checked to see if it made a difference that IE was open at the same time, but it is still opening in Firefox. Is Chrome set up as your default?
Norm
GIS Specialist
dkoppes
...works ok in Atlanta, GA...was wondering how to launch in Google Chrome App...
dkoppes
Yes...but it still opens in IE 7
nwray
I'm not great at LSP code, but it looks like it is using the "_browser" command to actually launch your web browser.  As far as I know, this should be launching whatever your default browser is.
Try typing "browser" in a cad drawing and see what browser it opens up on.
Norm
GIS Specialist
dkoppes
Hi Norm,
It says:
Enter Web location (URL) http://www.autodesk.com
Should I change this ???
nwray
It's the same for me.  I think that is their default, but you can put in "www.google.com" and it will open to google.  >>This<< is the command reference from Autodesk.  It says that this should open whatever the default browser is according to your registry.
I also found some other people in the forums who say this command is opening the wrong browser, but they have the opposite problem.  Their issue is that it is opening in Chrome when IE is their default.  >>Here<< is a link to a discussion in the forums, and >>here<< is a knowledge base article about correcting your default browser back to IE.  I haven't found anything about going back the other way.
I suspect that something is not getting changed correctly in your registry, like in the knowledge base article.
Norm
GIS Specialist
dkoppes
No luck...thanks anyway
nwray
If you are comfortable editing the registry, you can try this.
Open the registry editor
Navigate to "HKEY_CLASSES_ROOT"
Navigate to ".htm" and ".html"
The top (default) value for the .htm version should read "htmfile" and the top (default) value for the .html version should read "htmlfile"
If it does, try changing these values to "ChromeHTML" for the default value in both the .htm and .html fields. This should set Chrome as the default browser in the registry.  From what I gather, sometimes setting your default browser through the browser itself does not correctly change these values.
Below are some sample images.  As always, USE CAUTION when editing the registry.  Maybe take a screenshot of your original values to make sure you can go back to them.  I tried this based on the Autodesk article >>here<<  I can confirm that changing these values did cause the "browser" command to launch the correct browser, but I have not done extensive testing of any other systems.
I can also confirm that using the chrome "make default" command as well as the firefox "make default" command edited these values correctly, while the IE "make default" command did not.
Settings with IE as the default browser:
Settings with Chrome as the default browser:
GIS Specialist
fieldguy
In Windows 10 you can use Settings->System->Default apps.  Scroll down to "Choose default apps by file type".  Scroll down until you see .htm and .html on the left side.  Set the app to Google Chrome.
I don't remember where this is in Windows 7 but if you enter "default programs" in the start window you will find it.
nwray
Didn't know about that! It's under Default Programs, then "Associate a file type or protocol with a program."
Norm
GIS Specialist
