Launch Google Earth from point picked in AutoCAD Map 3D 2016
dkoppes
dkoppes
...is there any way to launch Google Earth to the point I pick in AutoCAD Map 3D 2016???
Replies (43)
FJankovsky
Patrice,
I just want to thank you again for sharing this routine. I have to show locations from my map to field crews and I am using this constantly. I have created a custom menu button for it to make it even simpler. Set the LISP to load at startup and one click and you've got the Google Earth image.
Great time saver for me.
info6XV83
Observer
Observer
so do i
is it fixed yet by autodesk?
"i don t want to be a programer - i am a user"!
nob
FJankovsky
@info6XV83
Did you get this figured out or are you looking for some help?
vladimir_michl
Fixed? It is not an internal function. But you can add this functionality through an add-on application. Besides the mentioned LSP routine you can also use the GEarth freeware utility - it works not only in Map but also in AutoCAD and even AutoCAD LT. See:
https://www.cadforum.cz/en/how-to-open-google-earth-directly-in-your-autocad-window-tip13512
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
Type a product name
