AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Launch Google Earth from point picked in AutoCAD Map 3D 2016
43 REPLIES 43
Message 1 of 44
dkoppes
4609 Views, 43 Replies
...is there any way to launch Google Earth to the point I pick in AutoCAD Map 3D 2016???
Tags (1)
43 REPLIES 43
Message 21 of 44
dkoppes
in reply to: nwray
Thanks ALL !!!
Message 22 of 44
Timothy.McCombs
in reply to: braudpat
This is awesome and very helpful, thanks for sharing!!!
Message 23 of 44
in reply to: Timothy.McCombs
this is very cool, works fine in civil3D 2017 for Belgium
thank you for sharing this!
Message 24 of 44
sebastien.baudin
It works in Switzerland too, with Map 3D 2014 and 2018.
Thanks Pat!
Kind regards,
Sébastien Baudin
Message 25 of 44
braudpat
in reply to: sebastien.baudin
Hello Seb
Thanks for Kudos, Happy WE, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 26 of 44
In Russia, too, works.
As everywhere, if CS is installed, of course. 🙂
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 27 of 44
I do not know why my message was marked as a solution!
It happened by chance!
How to remove it?
Message 28 of 44
Alexander,
I "un-Solutioned" your post.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 29 of 44
@braudpatwrote:
Hello from France
Welcome to the Autodesk / AutoCAD Forums !
In France we are using this routine "NM-StreetView" which launch directly Google Earth + StreetView
at the Point designed on the drawing ...
The routine can also launch "mappy.com" and/or "mapchannels.com" ... But I have commented the lines ...
I have always used "NM-StreetView" on DWGs with French Projections ...
Please let us know if "NM-StreetView" runs correctly anywhere around the World !?
Regards, Patrice
I like to know if you can help me to get you lsp working.
I am currently using window 10, google chrome, Microsoft edge and IE 11. All browser and os software are up to date.
Here is what I have tried.
1. Went to map 3d
2. Setup my dwg to the correct zone and coordinates
3. Create a manual point
4 Type appload in the command line
5.Next browse to where the program is saved on my hard disk
6. Menu pops up with the program and I click load.
7. Says lsp program loaded successfully
When checking all my browsers I don't see anything?
Any help would be appreciated.
Message 30 of 44
braudpat
in reply to: dkoppes
Hello
Please install Firefox or Chrome...
Don't let IE be your default Browser !
Try again...
Regards, Patrice
Patrice BRAUD
Message 31 of 44
delete
Message 32 of 44
@braudpatwrote:
Hello
Try again...
Regards, Patrice
Thanks for your reply I will give it a try on Monday and let you know.
Message 33 of 44
braudpat
Subject: Launch Google Earth from Point picked in ACAD MAP 201X / ACAD CIVIL 201X
Hello
Please use this routine instead !
It's the same "NM-StreetView" routine but with 2 different launches :
- data.mapchannels.com   with SITE2 ...
- GE StreetView                 with SITE3 ...
And the 2 launches are printed on the text / command Line (F2)
So if you have a Browser problem, you can copy / paste the 2 different launches to your favorite Browser !
Results are better with Firefox or Chrome !
Don't forget to assign the RIGHT Coords System / Projection BEFORE launching "NM-StreetView"  !!
( Command: MAPCSASSIGN or the old ADESETCRDSYS )
Happy WE, Regards, Patrice (The Old French Froggy EE)
Patrice BRAUD
Message 34 of 44
sebastian_meli
Can I get google maps to give me outlines of streets i.e. curbs,driveways trees... but in layout view as a site plan?
Message 35 of 44
sebastian_meli
Greeting!
Can you help me find where to look with regards to creating a site plan with details but not like a google map attacment i.e. lines and shapes (trees,drìveways,curbs and have a scale to this) sorry for that long shopping list!
Message 36 of 44
@sebastian_meliwrote:
Greeting!
I wish I knew of an easy way to tell you, however we use either AutoCad Map3d or Civil and use the imagery (Geomaps) to trace these areas with polylines that we creat linetypes for such as "Edge of road" or roadway centerline. There are some downloadable items in our area provided by the State that have the centerlines or the parcels and you would just have to attach them to your drawing.  Not sure where you can find maps for your area but try a search for Tiger maps of your area. Doubt this helped but I am sure someone will get some more help!
Message 37 of 44
belavyas
Need help please. The NM street view was working till now. But now gives me error as under.
Thanks in advance.
Bela
Message 38 of 44
FJankovsky
That's a nice little LISP. Very handy. Thanks
Message 39 of 44
belavyas
Hi Pat,
Getting this error recently when I try to launch this lsp in Autocad 2016 and 2018. Please help. Thanks in advance for your time. Was working before.
 Bela
Message 40 of 44
braudpat
Hello
ATTENTION : this Lisp can work ONLY with ACAD MAP or ACAD CIVIL !
Have you a MAP or CIVIL ?
The Health, Bye, Patrice
Patrice BRAUD
Technology Administrators
