AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
issue exporting to esri
5 REPLIES 5
2176nicola
746 Views, 5 Replies
hi all
I'm working with many geometry like closed polylines, mpolygons and topology; in all cases, exporting to esri shp, 95% of exported geometry has a kickback point (always first and last point).
doing mapclean solve the problem in the dwg file, but the issue come back again when export.
How can I solve the problem?
many thanks
N1k0
5 REPLIES 5
cedwards8511
in reply to: 2176nicola
How are exporting the features?
2176nicola
in reply to: cedwards8511
using mapexport..
antoniovinci
Try to _MAPEXPORT only the topology, sir.
2176nicola
in reply to: antoniovinci
thanks for reply but I've just tried and made the same problem..
Sorry to not know the meaning of the words "kickback point" and then (as a result) not to know how it's effecting your work then.
If you can upload a small drawing PLUS the exported SHP showing that issues we can look into it.
BTW: what Map3D version do you have?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
