Inserting JPEG with JGW file into AutoCAD Map 3D 2020
ccummingsEU5GU
Message 1 of 17
ccummingsEU5GU
A client has provided me a JPEG of a project aerial and a JGW file to geo-reference the file in AutoCAD. The image came from NearMap, but I still cannot upload the image to the proper scale and geolocation after reading through NearMap's troubleshooting section. Can anybody help me with this problem? Ultimately, I'd like to be able to work with the georeferenced aerial in AutoCAD 2018, not AutoCAD Map 3D 2020. Thanks in advance.
Replies (16)
Message 2 of 17
АлексЮстасу
Have you tried pasting this image with the MAPIINSERT command?
If you disable Modify Correlation and the file units (UNITS) correspond to the image units, the image will be inserted as needed.
Just in case, I’ll stipulate that for proper work with the image, you need to have not just an attached aerial photograph of sufficient resolution, but an orthophoto...
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 3 of 17
ccummingsEU5GU
I have tried using the MAPIINSERT command, but still with no luck. The aerial photograph is of sufficient resolution and is an orthophoto. How do I know what the image units are? Below is the information from the JGW file when I open it in Microsoft Word:
0.298582
0.000000
0.000000
-0.298582
-10840326.582095
4226987.457751
The name of the file is 'EPSG3857_Date20190408_Lat35.456102_Lon-97.375437_Mpp0.299' which I assume indicates the latitude/longitude coordinates, but I am unclear on how to get the image attached at a proper scale?
Message 4 of 17
ChicagoLooper
The jpg and the jpw go hand-in-hand. You have uploaded the jpg but not the jpw. Can you possibly upload the jpw too?
Chicagolooper
Message 5 of 17
ChicagoLooper
OK, you're at John Conrad Golf Course. Open an imperial template used by your office. Alternatively, you can use a brand new, clean OOTB template.
Warning:
Your jpg and jpw have names which are too long. Rename them like this or you'll have FDO connection issues.
0-Put Both the jpg and jpw in the same folder and shorten the names like this.0-Put Both the jpg and jpw in the same folder and shorten the names like this.
Now do this:
On command line=>MAPCSASSIGN. Enter OK83 in search box.
1-Assign coordinate system to modelspace.1-Assign coordinate system to modelspace.
After ASSIGN, go to Home Tab=>Data Panel=>Connect Icon. In Data Connect Palette, click 'raster' icon, browse to and CONNECT to your Nearmap jpg.
2-Add Raster Image in the Data Connect Palette.2-Add Raster Image in the Data Connect Palette.
In Data Connect palette, if your image displays <unknown> for Coordinate System, you'll need to correct it. It should be consistent with the jpw file or EPSG 3857, also known as WGS.84PseudoMercator.
3-To edit, click 'Edit Coordinate Systems.'3-To edit, click 'Edit Coordinate Systems.'
To give the Nearmap the correct coordinate system, do this.
4-Highlight DEFAULT then edit. Search for and assign EPSG 3857.4-Highlight DEFAULT then edit. Search for and assign EPSG 3857.
Verify the coordinate settings for Nearmap image and modelspace. It should look like this. Then click 'Add to Map.'
5-Your image CS=EPSG 3857. Your modelspace CS=OK83-NF.5-Your image CS=EPSG 3857. Your modelspace CS=OK83-NF.
The Nearmap image will appear in modelspace. It will also be listed in the Map Task Pane (MAPWSPACE=>On)
6-Nearmap image will be shown in Map Task Pane.6-Nearmap image will be shown in Map Task Pane.
Turn on bing imagery. Go to Geolocation Tab=>Online Map Panel=>Map Hybrid from dropdown.
7-Turn on Bing Hybrid.7-Turn on Bing Hybrid.
Nearmap in modelspace with Bing Hybrid shown in background.
8-Nearmap vs. Bing (Intersection of SE 115th St. & S. Douglas Blvd.)8-Nearmap vs. Bing (Intersection of SE 115th St. & S. Douglas Blvd.)
Done.
Chicagolooper
Message 6 of 17
ccummingsEU5GU
That works. Thank you!
Message 7 of 17
quicoLugo
hi
pero, entonces, qué indican esas coordenadas del .jpw?
but then, what do those coordinates in the .jpw file indicate?
gracias Looper
Message 8 of 17
koneillLR45R
Community Visitor
Community Visitor
Going back to what was said earlier about file name lengths. There is a limitation to 128 characters for Nearmap images to work properly. We are using Civil 2021 and have recently discovered mapiinsert wasn't always reading the jwg file. Turns out the location of the file was nested too deep in a project directory and we had to move it, plus rename it.
Since learning this, we haven't had issues with mapiinsert or using the Data Connection option.
https://docs.nearmap.com/display/ND/AutoCAD+Map+3D+-+Importing+Georeferenced+Images
Message 10 of 17
KDAddison
Convert it to a tif if you can because it will just cause trouble.
Message 11 of 17
ChicagoLooper
@quicoLugo wrote:
<<pero, entonces, qué indican esas coordenadas del .jpw?
but then, what do those coordinates in the .jpw file indicate?>>
  • Line 1: X-scale. This is the horizontal distance in meters represented by each pixel.
  • Line 2: Rotation about the Y axis.
  • Line 3: Rotation about X axis.
  • Line 4: Y-scale This is the vertical distance in meters represented by each pixel. Normally negative, because whilst an image has its origin in the top left corner, for Northings and Eastings the origin is normally considered to be the bottom left corner - hence why the scale is normally negative.
  • Line 5: X-reference point. This is the horizontal coordinate (or Easting) of the center of the top left pixel.
  • Line 6: Y-reference point. This is the vertical coordinate (or Northing) of the center of the top left pixel
Chicagolooper
Message 12 of 17
crypto
Great little tutorial, thanks for the help.
Message 13 of 17
jfreeseAZJZQ
I wanted to personally thank you for your wise words to "disable to modify correlation". I have been having some real issues with NJ Ortho photos, and now Nearmap where it would insert into QGIS correct, but not CAD. Was almost thinking I needed to export from QGIS as a Rendered Image, but this did exactly what I was looking for. Thank you!
Message 14 of 17
ClayE7XM3
Hi ChicagoLooper, thanks for the detailed steps. When I go to the home tab I can't see the Data Panel or Connect icon. I'm definitely using AutoCAD Map 3d. I'm trying to bring in a Georeferenced nearmap image too. Thanks
Message 15 of 17
Pointdump
Hi Clay,
To see the Task Pane, use command MAPWSPACE. To bring up the Data Connect pane, use command MAPCONNECT.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 16 of 17
ChicagoLooper
@ClayE7XM3
<<When I go to the home tab I can't see the Data Panel or Connect icon.  I'm definitely using AutoCAD Map 3d.>>
Make sure your current workspace is Planning and Analysis. Then do like this.....
Open the Map Task Pane like this.
Image-1Image-1
Then open the Data Connect Palette like this. Alternatively, you may click the yellow circled icon (see Image-1) on the Map Task Pane.
Image-2Image-2
Only Map3D and Civil3D have Planning and Analysis. If you run plain vanilla AutoCAD or Revit, you may want close those down to avoid workspace confusion.
Chicagolooper
Message 17 of 17
ClayE7XM3
Thank you Pointdump and ChicagoLooper!
