Insert Block doesn't connect to libraries
robin_wachtel
Observer Observer
Message 1 of 8
robin_wachtel
Observer
Observer
i want to insert a block in AutoCAD Map 3D. When I try to access the block via libraries it only shows: "File not Found. It may have been moved, edited, or deleted". I doesn't even give me the chance to connect or reach the block. Also I did never connect a library through insert blocks before. I already tried to reinstall the whole app but it won't work.
Replies (7)
Message 2 of 8
ChicagoLooper
Hello @robin_wachtel
Here are two options you may try:
  1. Go to OPTIONS=>Scroll down to 'Blocks Sync Folder Location' and verify the location of your Blocks (Make sure to put your block is in the folder named C:\Users\YOUR NAME\AppData\Roaming\Autodesk\YourProgram 20XX\enu\FavoriteBlocks
  2. Go to command line type in CLASSICINSERT=>Browse to your block
Chicagolooper
Message 3 of 8
robin_wachtel
Observer
Observer
@ChicagoLooperthanks for your help.
Unfortunately I am still not able to reach the libraries. I need to insert the block via libraries to get access to the variation of blocks within the file.
Message 4 of 8
ChicagoLooper
Are the blocks stored locally on your hard drive?
Or do you need to connect to a server to assess the blocks?
Chicagolooper
Message 5 of 8
robin_wachtel
Observer
Observer
The Blocks are stored locally. Either way I won't be able to connect to any library. The only thing AutoCAD shows me if i click on libaries is the screenshot I shared.
Message 6 of 8
robin_wachtel
Observer
Observer
Message 7 of 8
ChicagoLooper
@robin_wachtel
The default location for blocks is here
C:\Users\YOURNAME\AppData\Roaming\Autodesk\YourAcad 20XX\enu
You can put your block library in there under FavoriteBlocks. Your block library should be a dwg file containing all your blocks. You can organize your blocks by placing them in more than one dwg file so they're organized by category.
Go to OPTIONS=>Files Tab=>Blocks Sync Folder Location and verify the sync folder is mapped correctly so your Block Palette can find your library.
Chicagolooper
Message 8 of 8
Miguel_Sepulveda
Robin, When using Insert from Libraries, to insert the entire dwg file, you must select the folder, view the included files, and then right click insert and explode
