I have autocad map 3d 2023 but in this version i dont have Industry model setup aplication.
Where I can get this tool?
Is civil 3d have this tool maybe?
I need answer faster as soon as,
Nikola.
HELP in MAP3D says... https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/CloudHelp/cloudhelp/2022/EN...
Then this shows up after you open one of those DWT files
That's all you get in MAP3D if I understood your post correctly.
the product name seems to have changed. In version 2022 of Autodesk Infrastructure Administrator the tool was "Autodesk Industry Model Setup 2022". Now it is "Industry Model Setup for AutoCAD Map 3D 2023". You will find the Autodesk.IndustryModelSetup.exe in C:\Program Files\Autodesk\Infrastructure Administrator for AutoCAD Map 3D 2023\bin folder
Does this help you?
