>> Is there a way for the dialog not to show up?
As this thread is quite old ... do you mean the MAPEXPORT-dialog?
Then turn off FILEDIA, start the command with a dash in front ( -MAPEXPORT ) and that should work.
If that does not work please let us know your Map3D or Civil3D version (and you can also try to set CMDDIA to 0).
- alfred -
cmddia does the trick 😃
I was looking for the solution to the same issue... Thanks @Alfred.NESWADBA !
