IMPORT themes to other maps / HELP
- Mute
- Permalink
- Report
i found myself into a problem
im working with Autocad 3D Maps and AIMS 2016 and i have a whole map of my current city, i need to divide that map into almost 500 pieces
im connected to a MySQL database using ODBC, since i need to divide that map into a lot of pieces i cant apply themes to each piece once divided (i mean i can but its a lot of work), is there any way to apply themes to different maps with the same theme?
its a lot of work to apply 10 themes to each little map, just imagine applying 10 same themes to 500 maps, one by one
im just asking if there is any easy way to do this, i repeat, im working with 1 single shape (SHP) that has the whole city, i need to divide that map into 500 pieces and of course, apply themes/styles to each piece
example:
thank you
edit: for example, is there a way to ONLY publish to AIMS a selected area of your map on autocad 3d map? or to import same themes to other maps?
