How to create a SHP file with various attributes and different features?
Good afternoon.
Would you like to learn how to enter attributes to the drawings in AutoCAD Map?
I have worked in GIS software such as ArcGIS and Kosmo and it was always easy to assign a feature determianda activity code. However, in the Map'm unable to work well with this feature.
Desire to accomplish the following type of procedure (example):
  • Feature a swamp -----> Class -----> 11
  • Feature a forest -----> Class -----> 12
  • Feature of a consolidated area -----> Class -----> 13
And so on ... For each polygon, I wish to add an attribute to the "class" by a number.
I can not handle well the attribute table in AutoCAD Map 😞
How can I do this?
Thanks.. Smiley Happy
parkr4st
You can add the column to the data by editing the schema of the shp.
the how to  it is described in help  if you search for      To Edit a Schema
after editing, close and reopen the data table and the new column will be there
The result is like the  add column  in ArcMap
dave
