@Pointdump
Yes. Agree 100%, When using another GIS program you can clip using a polyline....but.....if you export that clipped image, does it keep the clipped boundary? Does that clipped image still retain its projection?
During export, will the exported image ignore the polygonal boundary and default back to a rectangle?
You may use AutoCAD's MAPIINSERT command to insert a georeferenced image AND use a polyline to clip it.
<<Best way: draw your pline first, then...when defining the boundary to clip, choose SELECT on the command line=>click your predrawn pline.>>
As you already know, you can't use a polyline to clip an image that's on the Map Task Pane as an FDO connection but you can use Resample Raster workflow.
Chicagolooper
