I have a project in which I need to convert some information to KML from DWG. I have been trying to do this with Autocad Map 3D, but have not fully succeeded, and was hoping someone could help me out, point out what I'm doing wrong or give me some advice on alternative ways to convert dwg to kml.
As an example file (I'll attach this post), I have made a circle in the center of the Helsinki railway station, and am trying to convert it to kml. For some reason I can not seem to get the coordinates right at all. The coordinates I get out in the kml file is instead focused around 20°N 50°E which is in not nearly in the vicinity of Helsinki.
Here is how I am trying to do the conversion:
- I start by choosing geographic location (GEOGRAPHICLOCATION), and from the online map data, I place the marker on Helsinki Central Railway Station (60.1719,24.9414)
- Next I choose a coordinate system based on WGS84, and perhaps it is here where I go wrong. I choose the EURO-LM-CONIC, because I don't know what else to choose. And I select GMT+2:00 Helsinki as Time Zone.
- Next I choose to put the marker at location 0,0,0 in my drawing with North pointing up (90degrees)
- I add some objects, for example the circle as in my example file.
- I use MAPEXPORT to export the objects to KML.
- End result: circle / objects supposed to be in Helsinki are now somewhere completely different in the KML file
Anyone who can help me with this problem? I don't understand why the coordinates are suddenly 20°N 50°E in the KML file.
Attached also the dwg but unfortunately I can't seem to attach the kml file, so I'll just copypaste it here.
converstiontest.kml:
<?xml version="1.0" encoding="UTF-8"?>
<kml xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:gx="http://www.google.com/kml/ext/2.2" xmlns:atom="http://www.w3.org/2005/Atom" xmlns="http://www.opengis.net/kml/2.2">
<Document>
<name>conversiontest</name>
<visibility>1</visibility>
<Folder id="kml_ft_conversiontest">
<Placemark id="kml_1">
<name>kml_1</name>
<Style>
<LineStyle>
<color>ffffffff</color>
</LineStyle>
</Style>
<Polygon>
<outerBoundaryIs>
<LinearRing>
<coordinates>20.0042489570959,49.9999999218034,0.0 20.0042328095989,50.0002386229927,0.0 20.0041844473856,50.0004755086928,0.0 20.0041042380562,50.0007087760203,0.0 20.0039927916157,50.0009366496048,0.0 20.0038509558443,50.0011573951018,0.0 20.0036798098571,50.0013693323955,0.0 20.0034806559021,50.0015708483882,0.0 20.0032550094577,50.0017604092815,0.0 20.0030045877046,50.0019365722529,0.0 20.0027312964618,50.0020979964417,0.0 20.0024372156824,50.0022434531581,0.0 20.0021245836233,50.0023718352394,0.0 20.001795779807,50.0024821654799,0.0 20.0014533069052,50.0025736040734,0.0 20.001099771684,50.0026454550072,0.0 20.0007378651546,50.0026971713639,0.0 20.0003703420806,50.0027283594851,0.0 20.0,50.0027387819705,0.0 19.9996296579194,50.0027283594851,0.0 19.9992621348454,50.0026971713639,0.0 19.998900228316,50.0026454550072,0.0 19.9985466930948,50.0025736040734,0.0 19.998204220193,50.0024821654799,0.0 19.9978754163766,50.0023718352394,0.0 19.9975627843176,50.0022434531581,0.0 19.9972687035382,50.0020979964417,0.0 19.9969954122954,50.0019365722529,0.0 19.9967449905423,50.0017604092815,0.0 19.9965193440979,50.0015708483882,0.0 19.9963201901429,50.0013693323955,0.0 19.9961490441557,50.0011573951018,0.0 19.9960072083843,50.0009366496048,0.0 19.9958957619438,50.0007087760203,0.0 19.9958155526144,50.0004755086928,0.0 19.9957671904011,50.0002386229927,0.0 19.9957510429041,49.9999999218034,0.0 19.995767232536,49.9997612217984,0.0 19.995815635604,49.9995243396156,0.0 19.9958958832664,49.9992910780312,0.0 19.9960073643536,49.9990632122413,0.0 19.9961492300328,49.9988424763535,0.0 19.9963204002799,49.9986305501916,0.0 19.9965195721098,49.9984290465151,0.0 19.9967452295013,49.9982394987482,0.0 19.9969956549407,49.9980633493146,0.0 19.9972689424972,49.9979019386635,0.0 19.9975630123296,49.9977564950735,0.0 19.9978756265136,49.9976281253085,0.0 19.9982044060701,49.9975178061997,0.0 19.9985468490642,49.9974263772155,0.0 19.9989003496386,49.9973545340762,0.0 19.999262217835,49.9973028234627,0.0 19.9996297000543,49.9972716388587,0.0 20.0,49.9972612175577,0.0 20.0003702999457,49.9972716388587,0.0 20.000737782165,49.9973028234627,0.0 20.0010996503614,49.9973545340762,0.0 20.0014531509358,49.9974263772155,0.0 20.0017955939299,49.9975178061997,0.0 20.0021243734864,49.9976281253085,0.0 20.0024369876704,49.9977564950735,0.0 20.0027310575028,49.9979019386635,0.0 20.0030043450593,49.9980633493146,0.0 20.0032547704987,49.9982394987482,0.0 20.0034804278902,49.9984290465151,0.0 20.0036795997201,49.9986305501916,0.0 20.0038507699672,49.9988424763535,0.0 20.0039926356464,49.9990632122413,0.0 20.0041041167336,49.9992910780312,0.0 20.004184364396,49.9995243396156,0.0 20.004232767464,49.9997612217984,0.0 20.0042489570959,49.9999999218034,0.0</coordinates>
</LinearRing>
</outerBoundaryIs>
</Polygon>
</Placemark>
</Folder>
</Document></kml>.
