@allelopath wrote
<<....I drew a Rectangle. When I click to see the Properties I don't see and width and height.....>>
If you select a 'rectangle' and view its properties, AutoCAD and won't give you the length, width or height. Although it might look like, walk like and even smell like a rectangle, it's really a closed polyline. It doesn't matter if the closed polygon is a square, rectangle, triangle, pentagon, or hexagon, the Properties Palette will only provide the area 'inside' the polygon and the perimeter length.
Your uploaded drawing also contained a 3D solid created using the BOX command and I'm guessing it's related to your rectangle despite the objects being located far apart. Since your box is 3-dimensional, the Properties Palette will display length, width and height when the solid is selected.
When using the box command, keep your eye on the command line. It provides prompts, in the form of instructions and questions, that you must follow or answer as you go along. Answer them correctly and you'll be fine. If you skip or ignore them, your box might get messed up or the command may fail.
As an alternative to using the BOX command, use the EXTRUDE command. (Extrude will give a 2D object height or Z-value, and thereby make it 3D.) First draw a rectangle to your desired dimensions and in the desired location. Next, invoke EXTRUDE using the rectangle as the object. Typically, a positive number extrudes the rectangle up while a negative number extrudes its down.
Chicagolooper
