Assigning global coordinates - Australia
sally.mcgregorJT3GR
Observer Observer
sally.mcgregorJT3GR
Observer
Observer
Good morning community,
Hope you are well.
I advise that I have been trying to assign the below coordinates to my drawing however, I have not been able to match the exact coordinates from the library.    Could you please advise if there has been any change to the coordinates or how can these details be added to the library.     I have checked the details on each within the library and I cannot find a match for TPNI-LM-94-CM
Coordinate details are as follows:
Coordinate System Parameters
CS_NAME: TPNI-LM-94-CM
DESC_NM: TPNI DB - (GDA94) Australia LCC (cm)
DT_NAME: GDA94
GROUP: AUSNZ
MAP_SCL: 1.0
ORG_LAT: -27
ORG_LNG: 134
PARM1: -15
PARM2: -39
PROJ: LM
QUAD: 1
SOURCE: TPNI
UNIT: CENTIMETER
X_OFF: 500000000
Y_OFF: 500000000
Datum Parameters
DESC_NM: Geocentric Datum of Australia, 1994 (GDA 94)
ELLIPSOID: GRS1980
SOURCE: AUSLIG
USE: WGS84
Ellipsoid Parameters
DESC_NM: Geodetic Reference System of 1980
E_RAD: 6378137
P_RAD: 6356752.314140348
SOURCE: Stem, L.E., Jan 1989, State Plane Coordinate System of 1983
OGC WKT Description
PROJCS["TPNI DB - (GDA94) Australia LCC (cm) ",
GEOGCS["GDA94",
DATUM["Geocentric_Datum_of_Australia_1994",
SPHEROID["Geodetic Reference System of 1980",6378137,298.2572221008916,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6283"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4283"]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",-15],
PARAMETER["standard_parallel_2",-39],
PARAMETER["latitude_of_origin",-27],
PARAMETER["central_meridian",134],
PARAMETER["false_easting",500000000],
PARAMETER["false_northing",500000000],
UNIT["CENTIMETER",0.01]]
Esri WKT Description
PROJCS["TPNI_DB_GDA94_Australia_LCC_cm",GEOGCS["GCS_GDA_1994",DATUM["D_GDA_1994",SPHEROID["Geodetic_Reference_System_of_1980",6378137,298.2572221008916]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["standard_parallel_1",-15],PARAMETER["standard_parallel_2",-39],PARAMETER["latitude_of_origin",-27],PARAMETER["central_meridian",134],PARAMETER["false_easting",500000000],PARAMETER["false_northing",500000000],UNIT["CENTIMETER",0.01]]
Thank you, any guidance would be greatly appreciated.
Thank you,
Pointdump
Hi Sally,
The only CM-unit coordinate system I see in MAPCSLIBRARY is XY-CM, which of course is not at all what you want.
You can use MAPCSCREATE to create a custom coordinate system. A nice wizard walks you through. Your parameters look do-able, but the large false eastings and northings, and most especially the CM units, might be awkward in Civil 3D/Map 3D. Both prefer either Feet or Meters.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
ChicagoLooper
@sally.mcgregorJT3GR
Australian projections using Lambert Conic Conformal (LCC) are typically in zones with units of meters.
Your project is using cm, not meters, and it doesn’t mention any zones. So weird.
Chicagolooper
sally.mcgregorJT3GR
Observer
Observer
Greatly appreciated Dave, I will give that try.  Thank you again for your expertise!
sally.mcgregorJT3GR
Observer
Observer
Thank you, yes it's very weird!   even more so it's a telco using those cords... go figure!   Thank you again,
