04:33 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear community,
I have a problem where a TIN (object class 3D face) is given(see attached) and my aim is 1. to extract the points at the vertices of the triangles, 2. remove the duplicates and 3. create a .txt file containing the X,Y,Z coordinates of the remaining points. Which do you think is the best command sequence to do that using AutoCAD Map 3D 2013;
Link copied
