Extract object custom properties data
Beka_Tchigladze
Advisor Advisor
Message 1 of 8
Beka_Tchigladze
hello
so I have several objects in my AutoCAD and I have defined properties for each of them and now I want to extract this data with data extraction tool but this property category does not show up how to extract this property data from AutoCAD?here are some screenshots below
2019-09-25_11-50-42.jpg2019-09-25_11-51-42.jpg2019-09-25_11-53-08.jpg2019-09-25_11-55-00.jpg
Beka Tchigladze
Infrastructure Design Engineer | BIM Automation Developer
Autodesk Developer Network (ADN) Member
Autodesk Certified Professional: Civil 3D & AutoCad
LinkedIn | Autodesk App Store
Replies (7)
Message 2 of 8
Koesti
Autodesk Support
Autodesk Support
Hi @Beka_Tchigladze,
from the screenshots, we speak about Map 3D object data not only properties.
There are several processes to export this data together with the graphical data.
One fast way is using MAPEXPORT command and choose one of the general formats like SDF, SHP.
Attach the exported format via FDO to the .dwg and open table view.
Other alternative is to add the .dwt to an new .dwt and run query to CSV to export the object data, e.g. to use them in excel.
1. Run Mapexport command
Select format SDF
Export and add object data
In Task Pane
Connect to exported SDF file
Open table view (select and copy to Excel or export to CSV)
2. Alternative run Map query
Close the .dwg with object data
Open new .dwg and drag&drop original .dwt to TaskPane - Tab Map Explorer
Query to report as CSV file
Video
Regards
Brigitte Koesterke
Technical Support Senior Specialist
Message 3 of 8
Beka_Tchigladze
@Koesti
So apart from these above, I solve problem. I use MAPEXPORT command and export as mif/mid with object data I needed after I import .mid which consist of information about "OD" as a text file into the excel.
thank you 🙂
Beka Tchigladze
Message 4 of 8
АлексЮстасу
You can try the ODEDIT capabilities for loading data into Object Data - ODEDIT_SETXYZ, ODEDIT_SETPROP, ODEDIT_SETTEXT, ODEDIT_LOAD_ATTRS, ODEDIT_SETID, etc.
And to upload them to csv - ODEDIT_EXPL, Explication.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 5 of 8
Beka_Tchigladze
unfortunately, I do not like to use additional tools.
thank you for reply
Beka Tchigladze
Message 6 of 8
АлексЮстасу
And I agree with you! 😀
I believe that such features should be in Map 3D itself.
And I agree that the MAPEXPORT-MAPIMPORT of mif/mid helps to use text-type data well.
Message 7 of 8
Beka_Tchigladze
yes, sometimes you should really dig into cores of software if you need to get what you want.
Beka Tchigladze
Message 8 of 8
АлексЮстасу
You can also upload to txt by query:
