I am using Auto CAD Map 3d 2017, currently working with more than 50-60 layers in one project. We need to deliver a list of them in pdf. My question... is there a way to export names of the layers in pdf or txt file?
Thank you!
Solved by АлексЮстасу. Go to Solution.
Solved by Gary_Braun. Go to Solution.
In the Layer Properties Manager window, you can export layers in Layer States Manager (Alt S).
In * .las file, text.
In Layer Manager, select all layers then ctrl+c to copy to clipboard. Open Excel and paste into new worksheet. It will even bring in the column headers for you.
Thank you, Gary!
It never occurred to me!
Everything can be easier than think!
